I've attached a picture of the engine. I am trying to locate the MAP sensor and EGR Valve. Can somebody please circle the areas where there at?
Thanks,
Mike
i don't know where the MAP is, but ECOs don't have EGR.
hrm..... well I guess the only thing left that could be related to my idle issue is the MAP sensor. There is nothing else. I've cleaned out the throttle body, IAC valve, and check for hose leaks which I did not find.
Still a damn idle problem.... Has to be MAP sensor
The map sensor is tucked behind your air cleaner, in the centre of the engine.  Just to the left of your throttle cables, there should be a small sensor going into the engine block, twist it (forget which way!), and then pull upwards.
could be  a TPS. why dont you just take it somewhere and  have them look at it instead of replacing parts. Not to knock you for trying to solve the problem yourself, but you didnt even know that your car doesnt have an EGR. What you could start doing is find out what range of resistance the sensors have (MAP, TPS) and use a multimeter to see if they are bad.
could be alot of other things too. dirty injectors, fuel filter, etc.   could go on and on
