okay so i got  some clear corners... how do you get access for the front turn signals... i assume three body bolts how ever do you go from underneath or up top... peace
pat
I have an 01 Cav..
it took me a bit to find out the turn signal housing clips into the headlight housing.. on mine, there is a little hole above them..
 take a long screwdriver and push the clip in..
It took a little bit of lovin to pop it out...
 my clip is about 11/2 in long, and pretty skinny..
hope that helps
"Z24 Dustbunny"
actually i think it doesn;t have to check the manual.. different setup unless someone can correct me ?
you can do either but unbolting the headlights and going in the form the top is easiet
