im wondering what this goes to i cant find the mate to it please help
Heated O2 sensor (rear)
Goes down the driver's side of the exhaust tunnel.
Check near the subframe for a plug the same shape.
That looks like the injector plug on the 2.4, but as far as the 2.2, I dunno.
Kardain wrote:Heated O2 sensor (rear)
well this car doesnt have it on the exaust its a 95 so could i take the pipe off the 97 that has it on it and put it on the 95????
you would need the cat at least since the rear o2 bung is welded to it.
Geeky wrote:On my 97 2.2, that plug is tied back and not connected to anything.
Same here,  I have been curious to what it was for exactly...
Just some odd plug hanging there, my motor had been replaced before I bought it so I figured it was just one of those things that were missed in the swap.
if the car doesnt seem to be having a problem ...
it probbaly doesnt go anywhere .......
car has crusie control ? or a/c ? or any other ?
most likely its a aux power  supply  for sumthing like that ....
especially if  it seems to be apart of the harness
Dale H wrote:if the car doesnt seem to be having a problem ...
Sorry, its none of the above.
I'm 100% sure its the rear o2 sensor plug.
I'm actually surprised that a code isn't being thrown with it not hooked up
Edited 1 time(s). Last edited Sunday, September 23, 2007 5:43 PM
yea it set the check engine light i took it to autozone they said it was the 02 heat sensor and a missfire in one of the cylinders i got the exaust  fixed but it still misses thou some times it runs good some time it misses
if your exhaust doesnt have an 02 sensor after the cat then you need to buy a heated o2 and have someone weld an o2 bung on your exhaust.
whiteboyz24 wrote:if your exhaust doesnt have an 02 sensor after the cat then you need to buy a heated o2 and have someone weld an o2 bung on your exhaust.
the 95 didnt have one the 97 does so i just took  that one with it off and put it on  and the miss fire problem i had is fixed  it was the coil packs so my cavy its alive and well
thank you guys for the help
-jason
