How the hell do you drop the motor in an 03 Cav? Mines making alot of noise and I wanna fix it but I can't find any hardware to move it.
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
easiest way for me was to pull motor and tranny at the same time... unhook the the cables for the clutvh if you are a 5 speed undo all your wireing to the motor take off your intake... remove your batter unbolt your exhaust manifold easiest way to undo it from the bottom of the manifold hook your motor lift to it and undo all your motor mounts there should be 4 of them... should be able to do it all with out unhooking your a/c and make sure to undo all your radiator hoses...
Twizted Deceptionz NationWide Car & Truck Club
no I mean the actual blower motor  inside the car. I posted it in the interior forum earlier but realized that it was the wrong place.
Richie Avery wrote:easiest way for me was to pull motor and tranny at the same time... unhook the the cables for the clutvh if you are a 5 speed undo all your wireing to the motor take off your intake... remove your batter unbolt your exhaust manifold easiest way to undo it from the bottom of the manifold hook your motor lift to it and undo all your motor mounts there should be 4 of them... should be able to do it all with out unhooking your a/c and make sure to undo all your radiator hoses...
to take out the AC? i think you're confused
it all unbolts without removing a single radiator hose, etc.
