I have a 98 sunfire with a 2.4 5-speed and I just replaced the tranny /clutch/ slave cylinder the whole nine, and now i have a whining noise coming from the engine/tranny when i get it up over 40kmh. I would appreciate it if anyone could help me out cause I have no clue
Thanks in advance for any responses.
Oh, nad i forgot to mention its throwing a core too. Its DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
is that the sensor on the AI tube between the TB and the filter?
lol
fast, reliable or cheap.  choose two.
Ok so that solves the code problem, now any help on the whining noise?
If it follows speed and not RPM, it's most likely your transmission.  Does it have enough fluid?  I know it calls for 2.5qts, but adding more will quiet it down.  I've got 4qts in mine.
2002 Cavalier 2200 5spd
The flywheel bolts or the pressure plate bolts are probably loose.  I was having the same problem and that was the case.  Locktite is your friend!!
Somebody threw in a supercharger.. Cool huh.
Watching you parade around my bedroom in a thong was a little like watching sea lions mate.
