Ok heres my problem...... 98 z24 coupe. left side of the car is fine. I have no  right break lights or turn, have parking lights. The front  has light but no blink. inside the car when you hit the turn i have a horrible buzzing noise.  Fuses are fine, checked the wires they seem fine! WHAT THE HELL IS WRONG??????
check the bulbs in the front.. pull them out and inspect them.. could be one of your bulbs isnt making good contact..
if in doubt, change the bulb.. or do a continuity test.
if that didnt work, check your flasher relay..
"Z24 Dustbunny"
Or the switch itself, possibly.  The stalk should be pretty cheap at a junk yard and it's easy to change out.
Check the wiring from the turn signal to the right wiring for the turn signals it sounds like you have a wire that is shorting out.
This is my 5 cents worth, (normally is would be 2 cents worth but I have adjusted it for inflation)
Car I drive:
99 Chevy Cavalier 2.2L 5 spd man (My daily car)
98 Ford Escort ZX2 4 spd auto
now you mention..before you go digging around for a column switch.. get some wd40/triflow/pbblaster and spray your connections @ the base of the switch... spend a few minutes going from left turn to right turn signal.. the switch is open to debris... massive crap builds up over time
i forgot.. one of the service vans that i maintain at work did that once...
"Z24 Dustbunny"
