I measured it at the filter, and got 65psi. I thought it was supposed to be 45. I also heard it's supposed to be higher then 100 coming straight off the pump. Any input?
the pressure would be the same anywhere you tested it. how did you test it at the filter? and why? were you having any problems. did you measure it with just the fuel pump primed?
in the service manual it says max psi is 58.
yeah my car won't start. i've narrowed it down to a fuel issue. i just used adaptor fittings to plug the gauge into the filter. turned the key on and got my reading
car won't start because of high fuel pressure? unlikely
thats what I said....I just want to eliminate the fuel pump from reasons why it doesn't run
relay bad contact or somethin
pump ran...apparently it wasn't firing the injectors though. car runs now
I have a similar problem... My car will start and run for about 2-4 seconds and shut off!
I changed the filter and I have the same problem...????
unplug your map sensor...i did and mine ran. is your theft light on? if the theft light is on you'll need to relearn your passkey
No my theft light in not on...I will try the map senors!
