my theft light is on and will not go off as well as all the other lights on my dash flash periodicaly. i have had to relearn the security code 4 times this week. any ideas as to where to start looking for a problem?
Hey my theft control has been turned on too ive tried the reset things many times but not very successful, COme on does anyone know the real way to make this work
i sent you a PM curtis let me know if it works
now when i turn it over i get a buzzing noise from the fuse box and it shuts down because of the security. after i do the relearn it runs fine until i shut it off again
is the relear when you lock the car with your key and then  you re-open the door with your key and get inside, shut the door and start the car?
Is that what the relear is?
 did you try that yet?
that relearn will not work or me i have to bump start mine 4 times in 10min intervals
if you have to bump start the car then the battery or starter might be bad?
have you checked both?
not bump start it like pushing it and popping the clutch. to reset the security on this car you have to bump the starter into  the flywheel,let sit for 10 minutes then repeat 3 more times
is there a way to diable the security system so i dont have to deal with this issue anymore?
would a weak battery or bad altinator be causing this issue? i have now noticed that my capacitor for my stereo system is no longer working.
sounds like you got a bad charging system, thats why you have to keep relearning your codes. try to figure out why your battery is dying and fix that. then relearn the code and it should take care of the problem. also, try checking your fuses, that will generally cause the anti-theft to go crazy.
another thing, you mentioned your stereo. did you disconnect the - side of the battery while installing it? ive done that my self installing a head unit and popped a fuse under the hood, which in-turn caused the anti-theft to come on, and the car to be dead.
the radio has been installed for almost 2 years. i have a buzzing sound coming from the fuse box when the secrity kicks in but when the security dose not kick in there is no sound.
