Water leak - Maintenance and Repair Forum
Water leak
Monday, February 04, 2008 2:46 PM
For about 3 months now my passaenger side floor is gettin water some days its like a small lake and its always cold so its frozen ive been looking but dont know where it could be coming from and i dont want it to rust so I wanna fix it..
Re: Water leak
Monday, February 04, 2008 4:17 PM
heater core. yours is broke. you need a new one.
Re: Water leak
Monday, February 04, 2008 5:35 PM
Heater core would be antifreeze and that wouldnt freeze like he stated. Do you have a sunroof? If so check the drain tube and be sure its attached to the sunroof drain and then runs out of the car like it is supposd to.
Re: Water leak
Monday, February 04, 2008 6:09 PM
mine froze. stepped into my car one morning and cracked my as because there was ice on the floor...
Re: Water leak
Monday, February 04, 2008 7:46 PM
check your floor mats
if they're wet, is the heater core
Re: Water leak
Monday, February 04, 2008 7:56 PM
A/C drain tube? Yes i know its winter and you dont use the A/C, shut up. A/C just doesnt cool the air it removes mosture too. The A/C can be removing the mosture but if the drain is plugged then its just going to run right back into the cabin.
I have ran into this problem with a few tractor trailers.
Re: Water leak
Tuesday, February 05, 2008 9:36 AM
Yes, if it is WATER on the floor, good chance it is the A/C drain tube. Defrost DOES turn on the A/C, and a plugged drain = wet carpet. If it is Cooland, then heater core.
Re: Water leak
Tuesday, February 05, 2008 11:44 AM
he said its froozen so that should rule out a heater core right away. If the coolant that leaks out freezes then you have bigger problems to worry about than a heater core leak. The evaporator drain is another good possibility, just never seen it on a j car.
