Does anyone have an idea were all grease fittings are located on the cavalier,, i found 2 of them and greased them  on front of car i believe are the tie rod ends....but is there any fittings on the back.. and is there more then 2? i just did a 100k tune up, changed plugs from ac delco to bosh plat 4+, and an oil change.../ air filter...am i missing anything? thanks
should have stayed with ac delco plugs ... just saying though .. i hated the platinums on my car
AFAIK, the tie rod ends are it unless you have non-stock ball-joints that have their own fittings.
id change the fuel filter on that tune up and also check your belt for wear and replace if needed.
The tie rod ends needs greasing, every tire rotation or 7000 miles
Secondly changing your plugs to Bosh plat 4, from AC Delco,  it has been posted before that non-Ac delcos, do short out ignition modules sometimes.
Fuel filter and air filter as mentioned before
throw them +4's in the trash.
stick with what your car came with.
