ok i had it out last night and it was running fine. i filled it will gas and brought it home.  this morning i went to go to work wont start. it tries to but nothing. what the hell is wrong with it. please help.
when you turn the key to the run position does the fuel pump prime??? you should be able to hear a whine from the fuel pump
Get somebody to lie underneath and bash the fuel pump with a mallet or something while you crank it, this sometimes tricks the fuel pump into starting and the car will start. Unfortunately this doesn't always work. But thats something i would try to start with.
(99 - Sunfire - Red - 2200)(95 - Cavalier z24 - Purple - 2.3 quad four)
now its not the fuel pump. about a hour after it wouldn't start i was messing with the spark plug wires and after a couple minutes it finally started. so my guess is that i need to get new wires.
mark yohn wrote:now its not the fuel pump. about a hour after it wouldn't start i was messing with the spark plug wires and after a couple minutes it finally started. so my guess is that i need to get new wires.
More than likely.  My mom had a 96 V6 fire bird that would do the same thing.  You can get short in plug wires and it'll cause all sorts of "fun" stuff.
-Chris
