wow pretty cool, apparently im due for 4 of them, can these be done with HPT?
12598577 12598584 N/A New calibration to ensure proper catalyst monitoring at idle.
12593521 12593529 N/A New calibration reduces the potential for engine stall. Includes change to avoid transmission damage during brake torque events.
12587611 12587615 N/A New calibration to improve generic scan tool operation and address cold 1-2 shift lag
12584709 12584719 N/A Control module calibration
http://www.cardomain.com/ride/2267189
Has to be done through TIS.
stupid question but can someone tell me wat this means?
12204473 12204437 N/A New calibration to address emission test failure
16259663 16259650 N/A New calibration to correct an EST problem. Also relaxes misfire diagnostics to prevent false setting of DTC P0300.
16254713 16254726 N/A Supercession - Software upgrade containing class II fixes
16253073 16253018 N/A Supercession - correct DTC P0502, VSS low
16250083 16249998 N/A Control module calibration
thats wat came up when i put in my vin number
once we get these codes who can fix them for us
GM only, i actually just booked my car in, maybe it can help my tranny shifts a bit..  GM has the Tech II tool so they are the only ones
As for you Jordan, looks like it will help keep emission failures to a true reading, as well as false misfire codes, causing check engine light to flash while driving.  as well as some minor bug fixes.
The Tech II is only half of the equation in the reprogram of the PCM.  I have a Tech II but i can not reflash a car unless I have access to TIS.  TIS is only accessible by people that GM allows to access it.  My password no longer works.
