So we just got everything done putting a used but good motor in 2002 w/ 2200 motor.
The fuel pump doesnt make a noise and it says error on the odometer.
I really need any info on how to fix this ASAP and if you have any info on what it could be please post back
any and all help will be extremely appreciated
I had this same message on mine when I was in an accident that left my computer laying on the ground.  I would check there first....make sure it is plugged in, and plugged in correctly.
Sounds like a battery 1 or battery 2 (maybe called ignition instead of battery) havent blown
hey my car got the same problem it says error sometimes and all my lights come on abs,check gauges,brake,theft, everythiiiiing. my tach drops and all of that i just had the pcm replaced for the s.c reflash but they werent the best people to deal with and i would much rather not bring my car back there i work at a garage but i have no clue where to start with things like this anyone have an idea? i checked the fuse for the pcm under the hood its fine idk what to do..any suggestions?
