99 Z-24 Convertible rear window timing - Maintenance and Repair Forum
Saturday, June 14, 2008 7:03 PM
I just bought my babydoll a 99 Z-24 ragtop. High high miles, motor is very quiet and it drives like a dream. Body a 7 with very very little rust. Problem is when we put the top up the driver side rear window stops about approximately a 1/4 inch from mating to the driver side front window. I suspect the window gear jumped a tooth. Then again I could be wrong. If you think I am right how do I adjust the timing? If you believe me to be wrong, what possibly is the problem and how do I fix it? Mommas loves the car, and as all married men know, when mommas happy everyone is happy.
Every day is a GREAT day. Its what you do with it that can mess it up.
Re: 99 Z-24 Convertible rear window timing
Monday, June 16, 2008 9:25 AM
You have to take off the rear quarter panel inside the car, and adjust the window stops and timing there. There's a post with the contents of the convertible adjustments manual from GM somewhere on this forum... I think it's a sticky too. Take a look around
Monday, June 16, 2008 10:57 AM
Mr. Lenko is correct. check it out
