i have searched and searched on here and everyone says the leak may come from the water outlet, or water neck but all the hoses and fittings are good, it drips around the left header tube, but it may be running from somewhere else, and again i have checked all hoses and inlets to the head/heater core. any help?
it comes out of the actual water pump itself not any hoses
totally wrong side, leaks on the drivers side near where the hoses go into the block, its a 2.4l
i had the same problem.... under the plug for the ICM and IDI cover, there is a plastic fitting where a rubber bunch of hoses, one metal hose, and a sensor meet. the plastic piece on mine broke off at the block.
there is a little lip that plug into the block with an o-ring on it to seal. the lip snapped inside the block. i had to fish out the plastic bits and the o-ring and replace it with a new one from the dealership. piece cost me $30 CDN, didnt come with o ring. i used my own o-ring that was a little thicker and a lot of red RTV as a gasket. problem solved, has been great ever since.
1997 Cavalier Z24
Bomz Short Ram Intake
Vibrant Cat-Back
KYB GR2 Struts
Goldline 1.75" Springs
RK Sport Upper Insert
RK Sport Lower Dogbone
Custom Tune by Shane @
innovativetuning@rogers.com
15.647 @ 88.02 MPH
oh, also mine was checked by grabbing that main hose that goes in there and wiggling it up and down and such. the plastic piece was moving. there are 2 bolts that hold it down, 10 mm i think. remove the bolt hold the metal line that comes from that and wraps around to back of the block too, will give you more room to play with if you have to remove or change it.
1997 Cavalier Z24
Vibrant Cat-Back
KYB GR2 Struts
15.647 @ 88.02 MPH
well i looked and it seems that the plastic piece is fine, no coolant seems to be leakin from it.
well no coolant seems to be lookin from there, but it is still stedily dripping from somewhere around there, is its not from the plastic piece or hose what could it be
could be that metal tube/pipe, could have rotted away. clean off that area and start looking, unfortunatly we cant do everything for you lol.
1997 Cavalier Z24
Vibrant Cat-Back
KYB GR2 Struts
15.647 @ 88.02 MPH
yea, i know lol. im just mad cause i just bought my z like 2 days ago, the dealership said they would fix it if it isnt nothin major, but if its a head gasket then they will refund my money in full. but it runs to good to be head gasket, i hope its something simple, i just wanna know what it is.
