Sorry I, once again, dont know what to call it.
But Im wondering how to install the pin into the crankshaft that holds the timing chain gear and crank pulley in place.
sorry so vague
any help please?
z24 - CAI - Magnaflow Cat - PaceSetters
--exhaust and unorthadox pulley soon
The pin should simply slide into the groove on your crank and the corresponding groove on your crank pulley.  There are basically 2 ways you can orient the pin at this point (given that it's symetrical).  What you're going to want to do is have the "longer" side of the pin facing out from the crank.  With the pin in its corresponding grooves and the bolt tightened down with an impact gun you should be good to go.
Hope that helps.
