Hey guys, went to fill up the 2.2L and the gas station was out of everything but 91
So i got 91 octane for the price of the cheap stuff ...and i noticed it took longer to use that gas up then the cheap stuff.
Why is that? I usually go a week with the cheap stuff but with 91  i went week and a half...almost 2 weeks
1997 Manta Green 2.2L Sunfire with Gt body kit
Normally running high-test in an untuned stock engine is going to net you zero improvement or even a loss of efficiency. Often the engine needs to pull timing to prevent detonation.
Regardless, if you're sure you're getting an improvement in mileage, then go for it. I'd definitely judge by mileage instead of weeks though.
    Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
So higher grade fuel isn't recommended for stock motors?
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
nope.....whatever the motor was designed for should be used.
i ran midgrade in my sunfire and had a little more go and a little less fill up, compared to regular. i think eventually it'll change your timing tables or w/e. midgrade ftw, unless you have a ford taurus.
At Your Feet You Find Your Place In Hell, This Is My Retribution - The Autumn Offering
You can get a increase without tuning with higher octane fuel, but it is not needed. There is amny factors involved.
So , does this mean its not good for my  car to run 91?
waste of money. the mileage you gained is all in your head. driving habits can chage mpg drastically
