Looking at the topic I can see how questions could be raised about the prowess of my mechanical skills.  I have been running four quarts for most of its life as specified by my owners manual (pg 5-85).  I just recently purchased the Haynes manual and I was looking through it and it specifies 5 quarts for the "2.2 OHC".  I think sticking to the owners manual is the way to go but I wanted to check with the .org first.  So which one is correct?
i would stick with what the owners manual says
US Air Force
Jet Mechanic
I wouldn't trust either one. Use your dipstick as a guide.
2.2 OHC im assumeing its the ECOTEC, but people have been known to call the 2.2 OHV an OHC.  I always use 5 qts in my eco.
As noted, assuming you're talking about the eco, it's 5 quarts.  The owner's manual was a misprint, if you ask a GM mechanic to look it up, the updated info from GM is 5 quarts.  Although, it doesn't seem to have hurt your engine.
It's always been 4 1/2 in my 2.2's
On GM's SI it says
Engine Oil with Filter
 2.2L Engine (Ecotec) - 4.8 liters - 5.0 quarts
2.2L Engine (LN2) - 3¾ liters -  4 qts (3.5 without filter change)
Hope that helps.
I guess posting the correct engine would help.  I was definately refering to the ecotec.  Sorry about that.
