I had my rear break cylinder go out on me today and I got every thing apart and now I cant get the cylinder out.  Do I have to take the backing plate off.  If so the bolts are all seized, is there another way to do this that I am not seeing?  If I need to remove the backing plate I am going to have to grind the bolts off.  Will I be able to replace them with regular style bolts?  Thanks
There are two bolts on the back of the backing plate.
you should be able to unbolt the W/C from the back with a t-6 wrench....maybe a t8, I forget.
There is enough room to swing the W/C out and no need to remove the bearing/hub assembly.
