Quick ?, how much coolant does the ld9 2.4 twin cam engine require? I need to buy some dexcool and dont want to buy too much or too little.. Thansk for the response!
98z24, lowered 2", aem intake, cat-back striaght pipes!, cop ligths in the front and rear, 18" liquid metal's, primer black, tint, full audio and video.
another ? I forgot to add with my first post is where exactly is the mass air flow sensor located? I picked uip some cleaner and I was going to spray it in there to clean things up a bit, I also did the sea foam, and well, wow! But I really need to find out wehre my mass air flow sensor is,thanks!
matthew christian wrote:another ? I forgot to add with my first post is where exactly is the mass air flow sensor located? I picked uip some cleaner and I was going to spray it in there to clean things up a bit, I also did the sea foam, and well, wow! But I really need to find out wehre my mass air flow sensor is,thanks!
look on another car. j-body cars do not have MAF.
Hmmm, well, I feel pretty stupid! Haha! hat is the MAP sensor? And what does it stand for?
Manifold absolute pressure (vacuum).
where is it located? I will search for a pic... But any answer is appreciated!
never mind, I searched, and found an answer, but I didnt find a pic, from what I understand there is only one bolt holding it in pklace? Correct?
