p0134? - Maintenance and Repair Forum
I threw a code, and I am not understanding why? I just replaced the darn o2 sensor like a month ago, and now it is saying no activity, all the wiring looks fine, but I dont understand why I would be throwing this code? I put a multi meter on it and it said I had .19 volts? The guy at advance said it should be 12 volts? Is this correct? It is the front o2 sesnor by the way and it is a crappy bosch... Any help is apprecaited! Mainly, what should the voltage be on the bank 1 sensor 1? I did it with the key turned over by the way, so I know the volts are accurate. ANy help, Please! I need to get a sticker in the next week and need this fixed!
98z24, lowered 2", aem intake, cat-back striaght pipes!, cop ligths in the front and rear, 18" liquid metal's, primer black, tint, full audio and video.
I also forgot to mention I had another code be thrown, it is for my speed sensor... Where is it located? I cant remeber the code, P503 P504 something in that range, but where is it located so I can replace it as well.
well, after looking at some pics online, I have made the assumption that my speed sensor is the one that has 2 wires connected to it on the underside of the tranny, right? I have a M/T by the way. SO I got that figured out, but what is the wire that connects to the bank 1 sensor 1 o2 sensor suppose to read? 12 volts? .19 volts? .5 volts? What? Haha!
Your O2 sensor reads in millivolts. It should bounce between .100-.900mv. It could be the sensor. Also sensor could be good, but wiring connections could be bad. If the ECU does not see the signal it is a issue.
Thanks alot! And I dont know if you remeber it or not, but what stopped my saga of hesitation and sputtering ended up being my o2 sensors, I changed to a bosch and had the problem, when I put delco ones in there (way expensive by the way) it cured it... Thanks for all your help about a month and a half ago! You are the man! And I think it was reading in mv's, that was my bad about .19 volts. So I guess all is good, and after I disconnected the battery, the code went away! So all my whoes are finally cured!
i had a friend back in the day had the same thing happen.   had a faulty stock o2 sensor, put a bosch in, same code came up a little while later.
best advise is yes to stick with ac delco.  i dont use bosch anything really.  never had, or heard many people having good luck with their stuff .
I will say I have always said use a AC o2 sensor (especially when replacing stock parts). Funny thing is I'm currently running a Bosch heated O2 sensor on my 01 with no issues. This was so I could install a heated one. I still believe in the AC stock parts. I have also seen times when installing a new part does not fix the problem right off until after a ECU reset (like disconnecting the battery for 10-15 minutes.
Yeah, but I have definitely reset it PLENTY of times since the change! Haha! But I must say as well, ALWAYS use factory replacement parts when replacing sensors and such, it will help you out in the long run, atleast this is true in my case!
