on my 97 cavalier the dashboard lights dont work the front daytime lights and high beams dont work the corner lights dont turn on and the rear lights dont turn on they only work when i signal and only one highbeam works i checked all fuses what could it be
i wanna say the switch on the column because i highly doubt all those bulbs would burn out at the exact same time.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
they burnt out in a week time one went after each other and i replaced all the bulbs and still nothing worked and i changed the switch also because the switch wouldnt engange so i got a new one in and not one light works on the car unless i put the turn signals on... its a very weird promblem
Have you had your dash removed recently? I was working on the stereo on my 97 and had removed the dash to install the deck. Ran out of time and just set the dash in the car. Well turned it on and no dash lights. There is a plug under the dash by the right side of the gauges that needs to be plugged in. Don't know if that helps you, but boy am I glad I did not put any screws back in lol as install was not done yet.
'97 Cavi 2dr, Kenwood HU, Power Acoustic EQ/ xover, PA 3 farad cap,
JL audio 6.5" Comps, Memphis 16-MC3004 FS amp
2x Kenwood 10" subs, RF P3001 sub amp,
4ga power and ground.
