Last night i turned on my wipers to clear off  some snow and ice that had built up on the windshield, and when i turned them off they stopped in the middle of the windshield. I tried to push them back down but they just shot back up. What would be the cause of this?
Mine did that, and would go back down if I kept them on "intermittent". It turned out to be a broken bellcrank in the wiper assembly.
    Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
There is a crank arm assembly that attaches to the motor shaft, and the linkage arms snap onto it. It has a small pivoting arm on it that is used to trigger the parking function. Remove the wiper arms, then remove the motor assembly from the car to inspect it. Place it on a bench so the motor is down, and the linkage is up. Inspect the crank assembly, and look for a small arm on a shaft, with a spring clip on it. If the tip of that is broken off (should have a small V indentation at the tip), the parking function will not work, and park them straight up.  Part is about $90 at a dealer, less online...    I bought one here:
http://www.buy-oem-parts.com/
