Hey guys, I was just inspecting my car for worn and broken parts, Ive notice my drivers side ball joint boot has broke apart, Its stocker balljoint, I am just wondering what size of drill bit is need to remove the rivits on the Balljoint on lower control arm.
Thanks in advanced.
Drill bit, your joking right.
You will be there are all day and night drilling.
If yours are riveted in, you need an air chisel to remove them, than you pound them out with a big hammer
I didnt know Cavaliers had them riveted in, never seen one that did, what year is yours
Rob wrote:Drill bit, your joking right.
stockers are all riveted in. only the replacements are bolted in.
Well I am not looking into destorying lower arm, It 2001 cavalier, If I had a air chisel then Yeah thats what I would be using, For getting back to the question, What kind of bit is needed?.
rich weeks wrote:Well I am not looking into destorying lower arm, It 2001 cavalier, If I had a air chisel then Yeah thats what I would be using, For getting back to the question, What kind of bit is needed?.
No offense but it sounds like you have idea what your doing/talking about.
First off you dont destroy the control arm, you use the air chisel to grind off the top part of the rivets, than pound the bottom part out. A drill bit, it wont get done that way, but you would have to measure the rivet and get that size plus lots of smaller ones, but it wont work that way
I'd go get the new ones, see what size the bolts are, and get the drill bit that will be the right size for them. Sometimes they are bigger.
-Seth
you might be able to drill the heads off and then pound out, got a tape measure? thats an easy way to tell.
nwuonline.com
Proud member on JBNW.org
JBO member since 2004
I've used a drill to get all my rivets out. Just need to know how to do it. Not that hard...
"You can only feed them semen for so long before their legs fall off."
