Cylinder 1 misfire - Maintenance and Repair Forum
Cylinder 1 misfire
Wednesday, September 23, 2009 4:16 PM
Alright I'm tired of throwing parts at this I hoping the intelligent minds of the org can help me.
It is a 96 2.4l with a p0301 --- cylinder 1 misfire
Parts I have replaced in order
Spark plugs
New ignition coil
Injector from junkyard
Moved number one plug just to rule out that it isn't fouled
I'm going to see if the fuel filter is clogged tomorrow afternoon is there anything else I can check.
Well I did a little more searching and found this cylinder 1 misfire
Guess I'll try the housing
Edited 2 time(s). Last edited Thursday, September 24, 2009 7:12 AM
Re: Cylinder 1 misfire
Saturday, September 26, 2009 10:46 AM
yes the housing would be a good thing to change,and did you check compression?
Saturday, September 26, 2009 5:31 PM
No I didn't check compression. The car only has 70,000 and doesn't smoke at all. I don't think it's compression. I'll probably get the housing from the yard in a couple days.
If that don't fix it, is compression the only other thing left?
