Top end let go on my z24 and I am in the middle of trying to strip it down to try to find the problem. Im stuck, anyone know what size the bolt is on the crank pulley, I do not have a socket in my set that is large enough so I am only guessing at 26mm. Anyone know? Might save me a few trips to the store.
Thanks
95 z24 2.4 quad 4
95 Cadillac STS w/ 360 whp N*
04 Yamaha FZ1
is it the LD2 motor? Original for the 95 Z24?
I guess I did not even notice that my signature was wrong. Its stock 95 with 2.3 motor. I had 2.4 listed in my sig.
95 z24 2.3 quad 4
04 Yamaha FZ1
I have it somewhere, just can not find it still.
Thanks for looking! Still have not had the chance to go back to it with the weather the way its been.
95 z24 2.3 quad 4
04 Yamaha FZ1
for some reason 27mm comes to mind, but let me check tomorrow and get you a correct answer
-- MyZcar
That would be great. Plan on going back to it thurs. I have a BA adjustable wrench, just dont want to strip the bolt if I can avoid it. Thanks
95 z24 2.3 quad 4
04 Yamaha FZ1
1 1/16" or 27mm will work. Use an impact. Makes life so much easier.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Thanks!
95 z24 2.3 quad 4
04 Yamaha FZ1
yep it is 27mm.
