Have a wobble, driver front area maybe - Maintenance and Repair Forum
Wednesday, April 07, 2010 1:05 PM
I can look at it again, but im pretty sure the tire checked out fine last I looked, as in no broken belts or lumps.
Its at low speeds, usually under deceleration, feels like the driver front area is running over a bump over and over
I replaced the strut mounts when I installed my dspecs and pro kit springs, like 8k miles ago, but that still doesnt mean they could have taken a beating and the one is broken?
I dunno, if anyone has experienced this let me know, so I know what to look for when I start taking the car apart.
Re: Have a wobble, driver front area maybe
Wednesday, April 07, 2010 4:55 PM
check your lug nuts make sure they are tight. and check to see if the strut assembly is tight also.
Wednesday, April 07, 2010 7:30 PM
lugnuts are tight, can you tighten the assembly without taking it off?
Thursday, April 08, 2010 9:45 AM
Wheel off balance? (have stick-on weights? Maybe one felll off?)
Wheel bearing have any play?
Thursday, April 08, 2010 2:08 PM
Jazer wrote:Wheel off balance? (have stick-on weights? Maybe one felll off?)
had all 4 rims balanced recently, all the weights are still there, I can check the bearing though.
Thursday, January 27, 2011 1:21 PM
Same problem here after installed my drop. Have you found what's causing this ? Borderlin3
Thursday, January 27, 2011 11:45 PM
Roofy Online
I would take the wheel off and have it spin balanced, to me it sounds like a broken belt and having it on a spin balancer would be the easiest way to check for a broken belt.
