Hello everyone,
I hope someone may be able to guide me in my little problem I am having with my 2001 cavalier 2.2L 5speed.  I have a pacesetter header (Along with a custom exhaust), and have received the code for a slow oxygen sensor several times.  I cleared the code and everything was fine.  On my way home saturday I hit a HUGE puddle while making a very sharp right hand turn.  The downpour had created a puddle where there has never been one before!  The water went clear up over my windshield and 2 minutes later when I arrived at my destination it started idling very rough.
I drove it home and the CEL came on and i had it read... bad front O2.  So i changed that guy out and it does the same thing, and on top of that, when i push in the clutch the RPMs rev up and want to go like to 2500 (If i shift over 3000 the rev up isn't as noticable).  Then the code P0171 comes up (after the other one was cleared) for the lean fuel and that doesn't seem to make any sense to be because my exhaust smells like gas and a very rich fuel ratio.  It almost sounds like it is missing at low idle but when I give it throttle it doesn't seem to miss...very confusing.
After reading online here I am going to try and clean my IAC Valve, does anyone else have any other suggestions on how to solve this problem?  I'm not quite sure where the IAC is exactly but that is my next adventure on the site.  Any suggestions would be greatly appeciated, and I threw in the story about the water in case that will help anyone!
Thank you for reading,
Kevin
Same issue on fine, i have cleaned it but it did not help. i am replacing it tomorow. ill let you know what i get!  i got a 99 with a pacesetter too...
Fireboy153
Brady Fire Co. - Station 150
Long Live The Sunflower! (yea its not so "cool")
Thats was a good post, Ima look around more when im up there, Going to do the IAC now, let you know how i fair out. Makes sense about the O2's being too far and not warming up.
Fireboy153
Well i have replaced my IAC, helped the idel for a fer hours then back to normal, well the bad normal. I putted the plugs and injectors, plugs are black, so my problem affects them all... not sure were to go next...
Fireboy153
Maybe replace the plugs and try that heated sensor?  I am not sure.  Hopefully someone else can be more informative.
Sorry about the spelling in that last one... A new header this weekend, new plugs too. if that alone does not help, i will go for the sensors, ill change both. Then its to a garage to diagnose it
Fireboy153
A new Header and New O2 in it seems to have worked for me. I am going to replace the IAC too, the tip is broke on it. Now i just spew oil from were the dipstick goes!! it never ends...
Fireboy153
Everything is ok, back to normal. so i think that was all my problems. how did you make out?
Fireboy153
