Hey everyone nice forum you got going hear! I am in the process of fixing my car its a 2002 NON ecotec 5 speed. I am looking for a right fender, a bumper and a rad, what years of cars can i take them off of and what makes do the parts all cross over from? (like gts and sun fires will work to?
Thanks David D
I believe 95-02 fenders should be interchange able. Rads should be the same, Bumper would be 00-02 will work. older ones like 95-99 have different bumper styles and headlight & signal lights. Either way to could fab them to work. Ive used 97 door pieces with my 01 cavalier. Even brake component's. Just got to make should with engine sensors and or mechanical parts I would check with auto parts store or wrecking yards or Gm dealer as a reference.
good luck with your'e project.
oh ok thank you! after i make the post i found most of the info i needed! I would like to put a better looking front bumper on are the ones from the z24 maybe. \or something aftermarket. But i dont want to sacrifice ground clearence.
fenders from 95-05 work on any cavalier. 95-99 you have to trim the corner light holder off the fender. Butbers 95-99 ARE diffrent from 00-02 and again from 03-05. radiators are pretty much the same across the board. Best bet would be to match up a car in the junkyard with the same engine. Since you have a 2200 it should be really simple to find J's with those motors at yards. You can add a bumper from a 00 Z24 for Ls Sport, but you will have holes where the foglights are, unless you get them housings and wire bulbs up for them to work. If you use a 95-99 you will need to modify them. Goodluck!
