i have a 1996 Sunfire 2.2L  i have never had any problems with it in the 4 years i've had it,  it has 310,000km and ran great.,  today while driving it just died,  no warning,  just shut off and i coasted to the shoulder,  i tried starting it,  but all it did was crank.  at home i first went to see if the fuel pump was gone,  it seemed fine because i could faintly hear it wind up in the tank,  i then checked for spark and it too was fine,  i took one spark plug off and the piston seemed dry,  and when i crank,  no fuel shoots out, so i am guessing it maybe the fuel injectors,  tomorrow i will buy those test lights for the fuel injection harness,  but until then,  can anyone think of anything else i could check that would cause a no start?  (Crank sensor, computer, etc.)
Just because you can hear it doesn't mean its putting out enough pressure. Test the fuel pump with a guage.
i did some checking on the fuel injection with a noid light and it looks like there is no power coming to any other the injectors,  i have a feeling its the crank sensor.  a week ago i got a check engine light come but i didnt have a chance to check it.  i have another parts car on my driveway, i would like to try and swap the crank senor from my donar car,  but i have no idea where it is,  is there anyone who knows where i can find some instructions on removing it?  also i read that if the crank position sensor is changed that the car has to re-learn it,  is that true.?
Please help :-(
crank sensor is on the back of the engine, down bottom, under the ignition coils/module assembly. no, it does not have to relearn it except for in very, VERY rare circumstances.
Thanks,  Found it.   but i have given up for the night,  after about an hour of wiggling and twisting i could not get the sensor out.  it turns freely but it feels like a o-ring is snagged,  i don't want to break it off,  anyone have a tip on what they used or what method can get this thing out?
Wiggle like a mofo, they get stuck in there.  Like Rich said channel locks and just pry it out.  It will pop out, but ur probably best buying a new one just bc.  But either way keep us posted!  Goodluck!
