Was wondering if anyone has experience with these codes?
Cleared them both and only the P0342 came back
Apparently they are  341  Knock Sensor Performance
342 Knock sensor low voltage
I changed out the Knock Sensor with a spare one and the P0342 keeps coming back
This is on my 98 Z 5 spd
Ok well I just looked in HPT under my 01 Z24 file and only found P0341. Camshaft position sensor performance. I do not see a P0342.
I found the 342 on here in the list
The 341 code never came back just the 342 code
sUiCiDe wrote:I found the 342 on here in the list
I will look at your file I have later, but my file does not have the Po342, which means it can not throw it.
Its on my 98z
This code is coming up with my buddies scan gauge
Edited 1 time(s). Last edited Monday, July 28, 2008 9:24 AM
Ok, I have looked at a 97 and a 99 file both have it. Po342 is " Camshaft Position Sensor Ciruit low input". It appears in 2000 this code is not in the ECU anymore. Still it si a camshaft sensor issue.
Hmm weird
I changed the CPS but still getting the code
sUiCiDe wrote:Hmm weird
Check the plug and wiring.
i have this same code in my 98 z24, changed the sensor and checked the wiring, couldnt find the issue, let me know if you happen to figure it out
New winter toy 1998 Z24
As always my on going project 1983 Z28
How is the vehicle running?
I'd start by getting a wiring diagram and tracing some wires down.
Do you have a scanner that can scope the sensor, MODIS, VERUS, etc.
