Cig Lighter and OBDII not working - Maintenance and Repair Forum
Thursday, February 03, 2011 10:37 AM
I've got a 2000 2.2L that I've had since 02'. Short of it is one night back in 02', mom went to move the car and stuck the key in the lighter thinking it was the ignition and that was all she wrote for the lighter. Well in 08', I got a new lighter when I put a new stereo in and it still doesnt work. At the same time I checked the fuse and the fuse was fine, but I replaced it anyways. The only reason I care at this point is because I need to get an E-Check and I need to clear the CEL before I can even get the test done, and of course I cant clear it because the OBDII port doesnt work along with the lighter. Any idea what might be causing this lighter to still not work? Thanks!!
Re: Cig Lighter and OBDII not working
Thursday, February 03, 2011 10:44 AM
Momma drinking???
Thursday, February 03, 2011 10:48 AM
Bad Ground
Thursday, February 03, 2011 11:00 AM
Im going to tear back into my dash soon, where's the ground for the lighter and OBDII located? Whats the color of the wire?
Thursday, February 03, 2011 11:15 AM
Ok, so I just double checked the Fuse it WAS blown. So i put another 20A in and it blew again. Def a short somewhere... Where should I start testing with my meter?
Thursday, February 03, 2011 11:32 AM
Roofy Online
Unplug the electrical connector from both cig lighers. The one on the dash and the one on the console.
Thursday, February 03, 2011 11:49 AM
There's only one lighter. Should the OBDII work after I unplug it depending on where the short is? Ive got the dash off and lighter is unplugged, bout to start testing for volts...
Thursday, February 03, 2011 12:54 PM
James Hammer wrote:There's only one lighter. Should the OBDII work after I unplug it depending on where the short is? Ive got the dash off and lighter is unplugged, bout to start testing for volts...
Could have sworn 00-05 had another lighter on the pass side console. Maybe it was 03-05?
Thursday, February 03, 2011 7:43 PM
Well, there should be, I know my 00 Vert has one on the console, and one on the pass side, near the passenger foot compartment on the little map holder thingy. You should really have two buddy. My 02 had the same thing.
