when starting it turns over  it poofs out of the carb takes about 15 sec then it will start. it ideals fine when you hit the gas it will spit and sputter and back fire out the muffler. ive replaced spark plugs ,coil packs, cam sensor, crank sensor the compression in 1 2 and  4 is 152  3 is 150  new  fuel pump the car is showing codes p0335 crankshaft positon sensor a circuit and p0341 camshaft position sensor a circuit range/ performance bank 1 or single sensor any one have any help   thanks   steve
That was really hard to read and your car doesn't have a carb.
It sounds like your firing order is messed up, make sure your spark plug wires are where they are supposed to be.
ok carb = throttle body and i pulled the timming cover and it didnt skip a tooth any more help
look at the map of maf sensor
jovan raices wrote:look at the map of maf sensor
Steve, did you make sure the firing order is correct?
Has nothing to do with the timing belt.
