Any tips you guys can give me on replacing them myself. Also are the bolts 5mm? I tried earlier and it seems nearly impossible to take them off. They are for a 97 2.2
www.gmofhouston.com
Is the best way to do is from the bottom? Or take the passenger side tire off and reach it from there?
www.gmofhouston.com
Remove them from underneath.They should be 5.5mm holding the coils.If there is room you might be able to take the whole mounting bracket off with the module and coils.Make sure you put back your wires to the right firing order.
Have you done it before?
www.gmofhouston.com
Along time ago on a 94 Cavalier 2.2.Use a 1/4 drive ratchet with extensions.
I don't know how you did it lol It's hard finding those bolts. Also you have to have skinny arms to reach way up there.
www.gmofhouston.com
Another question did you take anything off or loosen anything to get better access to the coils?
www.gmofhouston.com
just take off tthe bracket then play
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my ride." -Amen
On a 97? What bracket?
www.gmofhouston.com
Damn I just found that since I have a 3 speed auto the transmission is bigger and I have less room then the 4 speed autos.
www.gmofhouston.com
