my dads 03 auto cavy has a cel for low catalyst efficiency, it has a brand new cat on it but the code still persists, another thing i have noticed is when you really get on the car the check engine light will flash and the car will go into a sort of limp mode, any ideas for a fix?
you need a new coil pack. the flashing CEL is random multiple misfire... i have dealt with that many times already.
ecocavy16 wrote:my dads 03 auto cavy has a cel for low catalyst efficiency, it has a brand new cat on it but the code still persists, another thing i have noticed is when you really get on the car the check engine light will flash and the car will go into a sort of limp mode, any ideas for a fix?
First our cars do not have a limp mode.
low catalyst effciency could be a bad O2 sensor.
Flash CEL is a misfire. Could be coils/ICM, or bad plugs.
Yeah Eco's for some reason, go through coil packs.  Swap out the coil pack and you should be just fine.  A flashing CEL (as stated above) means the computer is detecting a misfire condition.
