so I dont know alot about ac stuff most the stuff I mess with doesn't have it. but I was doing my routine check and noticed with my stethoscope that my ac compressor sounded rough so I put a 3oz can of oil  in and it quieted down but if your listening to it with the stethoscope and rev the engine it sill doesn't sounds very smooth. but without the stethoscope you can't hear anything. it blows cold and turns on and off fine and gets cold pretty quick I'm just not sure if a rough sounds like that is ok. it does have 210k on it . let me know your thoughts thanks guys
My thoughts you ask? If it isn't broken, don't fix it.
well my only worry is it seizing up an throwing the belt I guess out would sound pretty bad to  do that
When the a/c clutch goes or starts to go, it will make an obnoxious metallic bearing noise. You will be able to hear it from a mile away (slightly exaggerated) but it will be loud.
Unless your experiencing poor a/c  or a very loud noise, your fine.
well with ac on its sounds rough when using the stethoscope but with it off  sounds fine.  either way it sound ok unless you use the stethoscope.
Your fine man. If you have to use a stethoscope to hear it, then it's fine. Leave it alone until it does actually go, if it goes.
would any pulley play at all be normal
