I just finished changing my top end and while the engine was appart I had the battery still hooked up. Now I tried to start it and the Theft System is on. Passlock Relearn isn't working. Any other walkarounds?
________________
 Greater Moncton Sport Compact Club
Greater Moncton Sport Compact Club -
Facebook -
Youtube
yep we are all dumb.
What car is this for?  97 and 01 have different procedures for relearn.
Edited 1 time(s). Last edited Wednesday, July 20, 2011 6:09 AM
Go to library, then FAQ's then passlock relearn.  Then do what it says for the correct year of your car.  If its not learning then ur not doing something right.  Goodluck.
Thought I'd update you guys with my gauges....
Self explanitory...
Key in ON position. There are 2 stages to this. Stage 1 turn on the dash, radio stays off. Stage 2 turns on everything and you can hear the fuel pump prime. Note; The Check Engine light is off. Also note; When the key is turned to stage 2, the Airbag light flashes a dozen times then goes out.
After a 5 second start attempt. Theft System light is on solid, Check Engine is on now.
(*** Take no note of the brake light. Ebrake is up.)
________________
Facebook -
Youtube
The theft light would be blinking if you were locked out.  Your issue is not passlock.
Subscribed!
ahahahahahahahahahahahah
aajajjaajjajaahahahhahahahahah
