I've been hearing this "clicking" noise when driving for about a month now. Seems to be coming from the front of my car, but I'm not sure
Kind of sounds like a rock stuck in a tire. Changes speed dependant on speed of car
Checked for a rock... not anywhere in my tires
I had nearly bald tires when it first started, so I thought it might be that a broken belt or something
After I changed them, didn't fix it. So I took the new tires off, put them on the back, and the noise is still present at same pitch, speed, volume, so obviously not in the tires
Here's the kicker... It gets quieter after I've driven a while
I've checked my control arms, and tie rods as best I know how to and everything seems tight and nothing strange
It was suggested to check for a rock in the caliper or something, but nothing there...
I had my wheel bearings changed about 50,000 kms ago. How often do they bust?
Anything else I could check? Any other suggestions?
Buddy Club Ecotec Cavalier
* More to come *
Wheel Bearing probably, know what kind you had it replaced with?
Whatever was covered by insurance
Probably cheap ones
How hard are they to replace? Whats involved?
* More to come *
Easy if you can change brakes you can change a hub...
32 MM Deep Well Socket
I think T55 Torx Bit
3/8" Hex for brake caliper
Look it up on youtube, there is a video from 1AAuto on how to change a hub on the sunfire they use. I'll be changing out 2 next week so I can tell you more then, I haven't changed one for a few years now...
