If my hvac vent selector is not working and air is comming out of every vent... Would it just be the one vac hose going into the hvac panel that I would have to check... Or do I have to look for the box that has the flaps that control the air flow.. I need to get the front defroster working again.. Thanks in advance
I know how to exactly fix this on a 2004 4 door cavy. Look at your PM.
anne shaffer wrote:I know how to exactly fix this on a 2004 4 door cavy. Look at your PM.
You can't just post it here for everyone else to see? Maybe others have this problem too
Well yea that's true. Sorry for my ignorance. Here is a post but it doesn't really have pics (I got the list off of someone else).
Try this link:
http://www.clubcav.com/forums/viewtopic.php?t=957
I am having a problem of uploading this link but don't know if that is my laptop doing that or what.  If you guys are having a problem too, let me know and I will go and take some pics this weekend and write up my own damn write up. lol
I had the same problem and it turned out the actuator that controls the flap broke off the housing making it nonfunctional.
Mine was the steel cable that connected the turn knob in the hvac to the direction controller near by the steering column was snapped at one end of the cable.
My problem was one of the vac lines came off the intake (right under the throttle body) was not connected... Wanted to kick myself when I seen it was off
ooooooh! Most of the 04 problems were the steel cable  was getting stucking and bending and breaking.
did a search couldn't find what I was looking for.
 new to cavvy's forgive me
 I have a 93 I know the HVAC controls are vacum acuated, but can't figure out why it only blows through the  vents and floor heater but not the windshield. could it be a bad actuator?
I have the dash torn apart now and can see all the lines .
 there are two coming from the fire wall (black tubes) only one is hooked up could this be the problem?
also on the back of the control there is one port not hooked to anything.
 I can change the settings and watch the switch from the back and it moves freely and clicks at each spot.
any sugestions ?
again sorry if this is a NEWB question.
