I have a 2004 Sunfire SE manuel Trans. and i was wondering how would i go about disabling the DRL's on my car?  Is it easy? Can anyone lead me through the steps?  Any links ? Thanks
Its the same as in the tutorial. ground the dark blue wire coming out of the BCM under the driver side dash. cut it and add some wire and ground it. someone can link you and get you more info.
Ill just bring this back from the dead.
why cant we just pull the relay? will just work but just keep the idiot light on?
I hate hate hate cutting and splicing, but need to disable the DRL's so i can install HID's
yea, pull the relay. its only 2 seconds of your time and virturaly no dirt!
Fireboy153
Brady Fire Co. - Station 150
Long Live The Sunflower! (yea its not so "cool")
Pulling the relay also brings up a dummy light, if I remember right.
Pulling the relay also causes the headlights to not work correctly.
I did mine without cutting a single wire, but I doubt many people have access to the tool I used.
damn tech II havin fool!!!
I have cut the wire 2 years ago and just grounded to where the obd plug is it has never faulted on me ....
EvoFire wrote:damn tech II havin fool!!!
I may have been called worse than just a fool before..
I just might have the tool, so spill it local 58! :p
