heres my problem, o2 high circuit voltage 2002 z24 2,4 manual 124k
The sensor would read 1.1v when car was cold, below 170
then would create the cel above,once the car reached 170 it would begun to drop but hover around .9 to 1.0?
if i cleared the cel it would act normal bouncing from 0.2 through 0.9
so i would let the car cool down and acts the same when i monitor it again
so I tried a new o2 sensor and everything is the same as above
It will not go into open loop or fixed fuel mixture of .46v at start up like it should, before the o2 sensor is heated up( this is a 2wire so it is not a heated sensor)
basically I need to know the reason it wont go into open loop or fixed fuel mixture of .46v at start up like it should?
thanks in advance
I can give you the information that you need , give our tech line a call and I can walk you through it.
Jason Norwood
NGK Spark Plugs Tech Support
1-877-473-6767 ext. 2
If not, reply with the location code and I will supply further information.
