Just looking to see if anyone tried the wynns engine tune-up in there j-body.
Its a can of additive that you add to your oil to
-quite noisy hydraulic valve lifters
-free sticking oil rings
-free sticking valves
-improve engine performnace
repower slugish engines
says it tunes your engine while you drive, just add entire contents to your crankcase
Anyone try this product?????, i am kind of afraid to add anything to my oil, as i never did before and i dont want anything to happen to my engine; but i am sure its safe and wont do any damage, can only do good i guess; and i have a 2200 so i could use something,lol...
I guess i dont have to do an oil change or anything right away like seafoam; just add it to oil and drive her everyday as the stuff works...
98 j-body sedan
^^^^Because i have a 2200, LOL... and when its cold it sounds like @!#$ until the engine warms up and then it sounds great, but when she is sitting say out side all day at work in the cold; then i start it up to leave you can hear like ticking and @!#$ for the first few minutes until the engine warms up; then its gone; i am assuming i have some of the above mentioned symptoms ...
I figured trying a additive could only help right?...
Anyone try this, or know another good products to quite old girls down,lol
Thanks
98 j-body sedan
the LN2 is a noise-maker. Mine has had the infamous LN2 "tick" since Ive owned it. When started in the cold, it sounds like a knock but it's fine.
As for oil changes, Mine gets valvoline "max-life" oil, and an ACDelco filter.
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
seriously fram filters are no good? i always get the fram touch guard fileter, easy to remove......
I put in castrol gtx most of the time, sometimes i use castrol high mieledge.
Thanks for the help; next oil change i will try a different filter and a good conventional oil.....
Thanks everyone...
98 j-body sedan
DO NOT USE Wynns engine tune-up!!!!! It blew up my engine and now I'm the process for a lawsuit cause they dont care about helping!
the dealership i work at carrys a brand called B&G, most dealerships carry it, their oil addative is called MOA, its expensive but i have seen the rep do demos of it and it works, every oil change i do i just pour a can of it in.
wynns just a cash grab. Just like people listed in here. Just use a good quality motor oil and filter.
