Hello,
I have a 2005 Cavalier I just did some steering column work on. I replaced the headlight/turn signal switch, but now the horn doesn't work. I tried to check all the wiring and fuses I could, but everything seemed to be okay. Is there something I'm just missing? Any advice would be appreciated. Thanks!
Did you get this fixed? My horn is stuck on. Everything checked out except the airbag. The contacts under the airbag cover for the horn shorted together. I did a continuity test with my multi meter to find that there was a connection being made, that shouldn't be made, unless the horn is being pushed. Maybe you have the opposite problem with your airbag.
1998 Cavalier sedan base 2200 3 speed auto
