First all all, Moderators please do not move this to any other posts, I'm just doing some research.
Question::::  I need to know who are using engine treatments such as enging restoration products and provide informations below that specifies the <b>Brand, How often do you use them, price, and feedbacks </b> in the format of:
Brand/Period/Average Price/feedback
1.
2.
3.
4.
5.
Thanks guys.
1. Seafoam
2005 A.D.
$6.08 (with tax)
Stuiff rules, I see direct results when I dump it straight to the throttlebody and makes crazy smoke.
come'on man, I'm serious about this.
I am serious too, there is stuff out there called Seafoam you know?
Ok, I might need to specify,
OIL ADDITIVES.  Sorry for the confusion and sorry to misunderstand you.
1.Slick 50
2.about every 3rd oil change
3.10-15 dolla
4.I love this stuff. I don't know if it was physically detectable but if its good enough for my grandpa its good enough for my Cavalier
5.
 didnt see anything that was supposed to go in the #5 slot.
Seafoam can be added to oil.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
Seafoam never made my car smoke like a fire, threw my ETS light on and caused it to shift like neutral bombs through all gears for 5 min, dosn't idle as smooth, but i did see some matter when i changed my oil. Sea foam sucks on my end and will never use it again.  Might have made my gas milage a tad bit better. Other wise no additives for me.
You shouldn't use oil additives.  Everything you need is already in the oil, anything you add might throw it off.
So I vote:
3. Nothing, cost $0
Jay
One huge aluminum wing - $200
More vinyl graphics than your ride can handle - $150
Decals for products you don’t even have - $10
500lbs of Car Audio equipment in the trunk - $1500
Getting slaughtered by a KIA - Priceless
…also, adding stuff like Lucas Oil Treatment or STP just changes your oil viscosity.
Lucas aerates your oil too, which is BAD.  I firmly beleive what Jay had to say:
J-kub wrote:You shouldn't use oil additives.  Everything you need is already in the oil, anything you add might throw it off.
So I vote:
3. Nothing, cost $0
Jay
I'm with the other guys who said
NO additives
It doesn't make sense to use cheap oil and then "protect" your engine by putting in all kinds of additives.  Most have been proven not to do jack anyway, if they helped so much, then the oil companies would add them to their motor oil in the first place.
Why not use the best oil in the first place, and not have to add anything?  Thats what I do, Mobil 1 all the way, and then you know your engine is completely protected without having to put in any oil additive garbage
My CarDomain Page
At VW anytime you buy a serive, not just an oil change, you get Krex engine treatment added to the oil, I don't know if it actually does anything or not we just do it.
If your looking for the best thing to do find a place with a Beilstein engine flush machine. I would swear by that machine, I've presonally seen it restore oil pressure, get rid of knock cause form lack of oil because of sludging, we had a car then went 20K miles with out changeing out and the beilstein flush cleaned out the engine, it works wonders but its not cheap, the filter alone for the machine that gets replaced with every use is $40, we charge $200ish for the service
I use QMI engine treatment that i get from my work.  its good for 50,000 miles and has PTFE in it.  Its not terribly noticeable on a 4 cylinder car, but my V8 van and my old mustang did run alot smoother afterwards.  cost is $24
I use BG products from the dealership i work at they are the best.
B G  MOA
about 6.00
every couple oil changes
i also use in fuel, trans, and the cooling system
2003 SE-R SPEC V
Custom turbo kit with a t66 turbo @ 15psi, Apexi safc2, custom side exit exhuast, JWT cams, JWT bsr, inovate wideband system, CP 8:5/1 pistons, carrillo rods, comp clutch stage 4, hks catch can, 10k hids. And more to come
I use Slick 50 oil treatment usually when I purchase a vehicle and then never again.  Slick 50 coats your engine with a plastic based compound, so multiple treatments could clog your oil passages.  I know it works b/c I have taken an engine apart after using it and even some of the hard crusted carbon deposits were covered with a hard shiny sheen of something.
I use a heavy duty gas treatment in combination with an oil treatment shorty before every "air clean" test every two years (don't remember the brand name - it comes in a pack marketed for taking e-tests) that loosens your rings and cleans your engine - just to help with the pass factor.
coclorchangecavi wrote:I use BG products from the dealership i work at they are the best.
B G  MOA
about 6.00
Yup^^^  I sell some of the BG stuff at my place and we sell MOA to customers complaining of valve knock and ticking and we pour that in after an oil change and the ticking goes away.
BG is the @!#$, we use it at the Ford/Chrysler dealership i work at
the only additive ive used, i just tried today, my timing chain was chattering (started after i changed the oil, used mobile one, previous owner used 15-40, will be switching back)
STP
soon to be every oil change
3 bux
solved my timing chain chatter
96 Sunfire, 2.4L Twin Cam 5 Spd, estimated 180hp
I have a timing chain clatter, when i get about 2k it stops. sounds wicked when you rev it up and it hits below 2k and the chain starts clattering. Did the additive fix your problem? I have not used an additive since i got the car back last feb from GM and this clatter just started about 3 months ago.
well last oil change i ran through a can of SeaFoam, and installed a K&N Oil filter and used  a quart of Lucas Oil Treatment as per directions in the place of 1 quart of oil and the car runs excellent. engine is much quieter. I havnt noticed much change with the seafoam but damn does all that smoke look great.. people were like whoa that dude has some SERIOUS car problems and looking at me with sympathy. haha. Id run seafoam over and over again just to see the smoke even if it doesnt do much for me. I do think it made the throttle response a little better and the engine idle smoother. Lucas oil treatment rocks though, it also works well in transmissions (as per the bottle which states if used by directions will not void factory warranty) put some in the tranny and it seems to be quieter and definatly shifts smoother.
ATF in the crank case. Add two qts drive for a while in low gear ranges, then change oil.
not really an additve but can be used to clean engine about every 30,000 miles.
1979 Impala Sport Coupe Aeroback
