I have power windows and when I role my driver side up it seems to lean a little bit to the right leaving a small gap in the upper left corner. It's really annoying when I'm on the highway you can hear all the air trying to come in. I usually have to push my window to the left when it's rolling up so it can roll up correctly. My passenger side is starting to do the same thing as well. Does anyone have this problem? Is so how do you fix it?
<img src="http://www.j-body.org/registry/ricanz24/Z24.jpg">
Well I know back when I had a neon, the window regulators on it would break every so often usually when closing the door with the window because it would put stress on the window and break it. Im not sure if cavys have the regulator or not but its worth a shot.
i have this also...on my drivers side...either its off the track or a guide..but i think our years their isnt a guide its more like a whole thinkg all around the window
Sounds like you have a bent window regulator .. had to replace both the drivers and passenger side in my 96 Z
<img src=http://domestictuners.com/banner.jpg WIDTH="400" HEIGHT="75" /img>
Hit 200 NA it broke once, Hit 213 it broke again,
Hitting 300 NA is further away than I thought.
 What does this regulator look like? How much does it cost?
It should be a metal piece that is attatched to the window and the track. Never had to replace one on teh cavy yet, but when I bought some for my neon they were $50 each (2 per window...front and back).
 Looking around its not like a little piece its a big piece in a form of an X cheapest i had found so far was $50 for 1
