Headlights - Maintenance and Repair Forum
Headlights
Tuesday, March 15, 2005 4:09 PM
help i have a 98 cavalier z24 convertible and my lights don't work at all, maybe i need a wiring guide or something cause it says my bright are on but there are no lights on and i can't turn the brights off any imput will help electricians wanted
Re: Headlights
Tuesday, March 15, 2005 6:29 PM
their is a connector under the battery tray that likes to corrode, check that, the cause is a leaking battery. The bulbs should be hot all the time you switch grounds them. The orange is the power side the dk blue is ground on the low beams and the pink is ground on the high beams.
1979 Impala Sport Coupe Aeroback
Re: Headlights
Wednesday, March 16, 2005 12:31 PM
That's exactly what it is....I just cleaned mine...i ended up having no daytime running lights or highbeams..just normal lights...it was the connector all corroded up.....you should find it behind the washerfluid bottle...
~-=:'98 GT:=-~
