Well, after 115 thousand miles, my cluch is finally starting to go.  Can anybody give me an estimate what i can expact to pay to replace it?  It's a 96 Sunfire GT
Thanks
Promise that forever we will never get better at growing up and learning to lie
I got my sunfires clutch replaced on a 95 SE i paid like 800 canadian from what i remember that was for a new throw out bearing and the whole set, which they probably will do.....  the everything so that you wont have to go back and change anything else say a year from now if the throw out bearing goes......  change it all at once... save the headaches... and depending on the state of your flywheel
bla, not looking forward to that
But thanks
oh yea, and can someone please list everything that will need to be replaced.  Just so i sound a bit more knowledgeable when i call around for estimates....
thanks again
^^^^  sounds about right,
Tell them you want a complete clutch set (or get your own save a few bucks), kit includes this
Clutch disk, pressure plate, throw out bearing, alignment tool, pilot bushing.bearing
Tell them you want the flywheel turned also so you get a smoth surface.
Now the big thing you might be able to get them on it the GM syncromesh trannsmission fluid, don't tell them that what it takes until you drop the car off. it like $8.00 a QT for the shops.
And since the tranny is down and axles are out, tell them you want new output shaft seals down also.(these are where the axles goes into the tranny like $6.00 each).
This should help you alot and hopefully not get you ripped off.
<img src=http://domestictuners.com/banner.jpg WIDTH="400" HEIGHT="75" /img>
Hit 200 NA it broke once, Hit 213 it broke again,
Hitting 300 NA is further away than I thought.
When I did the OEM replacement on my 90 Cavy, I went with the whole deal.  It came to around $350 after all was said and done.  I paid my dad's friend some $$ for guiding me along and letting me use his lift/tools.  I forget what he got the clutch kit for, but I imagine it was cheaper then most because he works at a large GM dealership.  Good luck with it!!
