Last summer just before i stored the car i noticed it ran hot fluid was down. SO i filled it up parked it for the winter come to find out the Coolant i put in all must of leaked out. There was NOT a drop in the collant bottle which was full the day before i stored it.
Car has 106 k/m on it. Im guessing water pump?
just take your time and check for the leak, my gt 2.4 was leaking from the top outlet housing the o-ring went bad.
<img src="http://www.trenzhost.com/files/haroracer/black.psd.gif">
check on the back side of your engine. thats were mine leaks, there is a gasket that might be worn out
Before you can figure out what's wrong, you have to know where the coolant is going. You gotta find where the leak is coming from.
Club Vantage ::
importfighter.ca :: RIP Trux0r...
mine was leaking big time i dont know wut the hell was wrong just put some stop leak in there and it never had a problem since
I saw it leaking yesterday while i had it up a lil bit looked like the back of the motor.. Which the car was cold never started it and it was leaking. I thought it owuld only leak when hot?
O.K> really only two possible places ..
Check the Thermostat housing area (this would be the big metal pipe coming from the radiator to the back of the motor), it has to bolts holding it togather. If it leaking from there take it down and replace the thermostat and o-ring.
While in the area of teh thermostat look up and to your right (towards front of motor) this will be your water pump, verify the water is not coming from the sep hole on the top or bottom.
You can also check the heater core drain on the fire wall, if you core is bad it will leak through that drain or into your Pass. floor board.
Hope some of this helps.
<img src=http://domestictuners.com/banner.jpg WIDTH="400" HEIGHT="75" /img>
Hit 200 NA it broke once, Hit 213 it broke again,
Hitting 300 NA is further away than I thought.
When you turn the car off, the coolant is still pressurized for sometimes even several hours after shutdown. If there's a leak anywhere in the cooling system, it will still leak after shutdown until pressure has been relieved.
Is it leaking on the back of the actual block? or is it leaking just in the general "back of the motor" area?
Club Vantage ::
The car was off for more then like 20 Hrs, what i saw it was comingf rom the back of the motor.
yeah ... more than likely it may be from around the back of your motor, (the water pump) because our J's have a sub frame, and if you've hit a pretty big bump or something..that jolt has went all the way up to the water pump... the pump is like 50 some bucks...buts its a tough job ... takes like 5 hours or so. ...but like everybody else said...check hoses, lines, etc. first...may be something small.
When I step on the gas, I want people to think the world is coming to an end! - Homer J. Simpson
Well the coolant related items on the back of the motor are the Water Pump, Thermostat Housing, and Head Gasket.
Club Vantage ::
sounds like he is refering to a head gasket.
Orange Syn wrote:Last summer just before i stored the car i noticed it ran hot fluid was down. SO i filled it up parked it for the winter come to find out the Coolant i put in all must of leaked out. There was NOT a drop in the collant bottle which was full the day before i stored it.
I have a coolent leak also i took mine to a local radiator shop and he said that chevrolet's radiators are the worst and he said that he keeps like 150 parts in stock just for chevys... so i think i am just going to have a new radiator installed.. i can't find the leak and stop leak sucks...
