if anyone has initial thoughts, i'd appreciate. i can't shed too much light on it though...
engine's revving at 1300rpm consistently. it's normally about 800. it's a 2002 2.4 with 175,000km on it.
that's it for the symptons! delco plugs are only about 15,000km old.
thanks!
  <a href="http://groups.msn.com/2000Cavalier/2002z24.msnw" target="_blank">2002 Z24</a>
<img src="http://registry.gmenthusiast.com/images/pwdelta/moonwalk.gif" border="0" />
hmmmm....
ok, how about if i add in that it seems to rev even higher when i start it up. closer to 2000rpm for a few seconds then drops.
help?
check your vaccum lines... it could be you have a small leak of some sort.
yeah....check for a vacuum leak....check the vacuum line from the manifold to the map sensor......ive seen a couple of those start to dry and crack
thanks guys. i'll see what i can see!
i'll let you know
