every thing is working correctly.  i have a 2001 cav 2.2l  and 60,000 mi
The only maintenance i have done is oil changes every 4,000 mi
what should be the frist thing i need to do(like what need the most maintenance)?
1.
2.
3.
the cav is 60k mi and year 2001
belts
check hoses
check brakes
spark plugs @ 50K
lube the chassis every 3-5000k (w/oil change)
it's all in your book that came with the car, get a Haynes or Chilton's manual for more.
what is the chassis???
what will happen if you did not lube the chassis for like 2 years?
feul filter change,  raditor flush,  and tranny fuild change too.
You might want to start thinking about changing the transmission fluid about now.
You have 60k and have the original air and fuel filter, your not to bright at all.
They should both be changed every 30k
dan j wrote:what is the chassis???
 Step away from the car!
Jay
One huge aluminum wing - $200
More vinyl graphics than your ride can handle - $150
Decals for products you don’t even have - $10
500lbs of Car Audio equipment in the trunk - $1500
Getting slaughtered by a KIA - Priceless
Rob S wrote:You have 60k and have the original air and fuel filter, your not to bright at all.
Completely uncalled for.
Like everyone else is saying, change all your fluids (including brake fluid). Inspect your brakes. Inspect your tires (they should be about gone now).  Change all your filters (transmission, fuel, air, etc).
Correct me if I'm wronng here, but I believe the spark plugs on an 01 Cav are 100,000 mile plugs.  Wouldn't hurt to pull em out and have a look, but they shouldn't need to be replaced just yet.
Your owners manual should have a maintenance schedule towards the back.  There are little things that needed to be done long ago, but at 60k they've added up.  Mostly it is fluid, belt, and filter checks and changes, though.
A chassis lube basically keeps all the joints and hinges functioning smoothly.  It's not a critical thing, but it does keep things from getting annoying squeaks (and over a longer period, wear, and eventually damage).
how do i lube the chassis??
what  kind of oil do i use??
where is the chassis
"Chassis" is basically the body and frame of a car.  For instance "a rolling chassis"  refers to a complete car without engine or transmission.  It's probably easiest to take it into a shop to have the chassis lube done- it's relatively cheap and would take much less time than trying to do it yourself.
If I'm wrong, please feel free to educate me.
u mite wanna start thinking bout changing that oil before 4k miles.. i do mine about 25-2800 miles... fuel filter 20k miles (just did it yesterday had never done it before took me about 2 1/2 minutes ).. air filter/ coolant flush/tranny fluid.. spark plugs (which ive never done i need to have done sooon)
If you have a Wal mart near you they "lube" you car or they should if you get thier top oil change package.. Other than that its actually grase joints they "lube". id check your brakes!!! not sure if anyone said that yet them bad mamas ashould be about gone now with 60K on it.. For me I also swap all my fuses (dont ask) every 20K in the fuse box that is.. I just don;'t like old parts.. Ive changed out alternators before because it wasn;t "pretty" enough lol
Go to a local place and just ask for a tune up (they may have different types, as they dow here I live) Me personally I'd be weary of the transmission fluid change and such I did that at 68K on my first J and literally 3 days later my trans blew.. May have just been a quirk but I've heard other stories about stuff happening after they change the trans filters
Also check your engine mounts i.e. rev the engine from the engine bay see how much roll is in it.. bad mounts=lost power! my Org. mounts went out @ roughly 30,000 miles on all 3 of my J's I've had esp. the bottom one!
Hope this helps!
beer is like a chick.. well not really its just beer, it be cool thou huh?
As pretty much everyone has stated... air, fuel filters... brakes... chassis lube (any moving parts.. control arm bushings, ball joints, etc). Make sure they use a white lithium grease, or it'll start squeaking even if it didn't before!!
Lube the e-brake cables.. oil the hinges.. white lithium grease on the rubber door/trunk moldings... spray some WD-40 in the door locks and mechanisms...
Check for burnt out lightbulbs?
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
Old English 800 wrote: For me I also swap all my fuses (dont ask) every 20K in the fuse box that is.. I just don;'t like old parts.. Ive changed out alternators before because it wasn;t "pretty" enough lol
now thats just weird.. and not necessary..lol so do u have the cool new "05" fuses how much hp does that add?
30 hp @ the wheels of course
I know it isnt necessary but hey they all match!
Puts crack pipe down.. I'll shut up now
